Using VLC's "Media convert" to convert some files that other apps choke on works fine.
But I would like to batch it.
I see VLC can do anything by command line, but working it out is a nightmare.
( http://www.videolan.org/doc/vlc-user-guide/en/ch04.html )
Is there a way to do an operation and capture the equivalent command line?
				Results 1 to 1 of 1
  VLC Command Line - how to reduce FPS and keep speedBy mkvideo in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2013, 15:51
  Need help with VLC command line conversion.By NGage^ in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2012, 12:20
  Player with the command line.By Belini in forum ProgrammingReplies: 2Last Post: 29th Mar 2012, 07:29
  Command-line command for fixing AVI?By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 03:23
  Trying to put together a VLC command line in Mac OS XBy llee782 in forum MacReplies: 4Last Post: 30th May 2009, 05:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
