    Hi all. Please excuse what is probably a duplication of other posts on similar subject but I am weak on video
    manipulation unless it is very simple.
    Can someone suggest a simple to use app to put hard subtitles from a srt file to an avi video and specify the step by step process.
    Thank you.
  2. Member netmask56's Avatar
    You can use avi-ReComp to do it and a step by step method is shown here http://www.my-guides.net/en/guides/general-video/how-to-hardcode-subtitles-to-avi-file...-recompression
    BUT the assertion you can add hard subs to a video without re-encoding is just plain wrong. You are modifying the video frames.
    Also you can skip the part dealing with ass subs and subtitle edit
    TheVoiceIsAnotherPerson ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030
    Thanks for reply mate. Worked perfectly.
  4. I'm bookmarking this page. The above click-by- click instructions with screenshots is something even I can follow.
