    Hi, I've used tsmuxer for a while now without any trouble (dvd vob files to 1 m2t file mostly). But now, each time I try muxing, the output video is always out on sync. I really don't know what to do. Any ideas ?
    Thanks to answer
    Are you using same tsmuxer version?
    You could also try vob2mpg and then the mpg to m2ts with tsmuxer.
    Yes, I'm using the same version. I've managed to used another program called vobedit with tsmuxer, althought it's a bit tricky. I'll try vob2mpg and see what it's worth. I hope the image quality will not be altered.
