    Hey I'm trying to have some blu-rays ripped by makemkv by way of mkvmerge and solveigmm avi + mkv trimmer; however, I need to find a way to black out some scenes while keeping the audio playing (basically cutting out nude scenes).
    Does anyone know how to do this with the software I listed or by any other software that won't convert the video/audio so I don't lose audio/video quality.
    Thanks in advance for your input.
    Without reconverting it's very complex. You must cut, demux audio, convert a short black segment with exact same video properties, multilplex and join back everything...
    Thanks, Baldrick!
    What about changing the video via effects? Are there any recommendations on editing software that can alter the saturation, etc. of a point in a file without losing the audio/video quality in the rest of it?
  4. You can make subtitles where the background color, while usually transparent, is completely opaque and black. Then mux them into the video. That'll avoid having to reencode the video.
