Results 1 to 21 of 21
  1. Member brassplyer's Avatar
    Is it correct that the "native" format for HD is progressive video, that there is circuitry in HD tv's to accommodate interlaced SD DVD's but HD is really progressive?
  2. No. Some Hi-Def TV broadcasts are interlaced, some Blu-Rays are interlaced.
  3. Not sure what you mean. All fixed-pixel displays (LCD, plasma) have a native progressive resolution and everything is scaled (and deinterlaced if necessary) to fit those pixels.
    But in terms of production standards, there's 1080i.
  4. Banned
  5. Member brassplyer's Avatar
    How does an HDTV present interlaced material? As fields the way an SD tv does or converted to progressive images?
  6. Originally Posted by brassplyer View Post
    Progressive TVs IVTC or deinterlace. Quality of those operations vary from model to model.
  7. Member brassplyer's Avatar
    So what's the point of broadcasting 1080i?
  8. The industry wanted a higher resolution than 1280x720p60 but didn't want the bandwidth of 1920x1080p60. Since they were used to interlaced video they decided to go with 1080i30 -- half the bandwidth of 1080p60 (as uncompressed video) and about the same bandwidth as 1280x720p60. In my opinion it was a huge mistake. They should have gone with one progressive resolution (near 1920x1080 but mod16!) and allowed various frame rates: 24, 30 and 60. Since HD broadcast is MPEG 2 a computer is required at the receiving end to decompress it (ie, no pure analog TVs). That means a frame buffer and a graphics card. So frame rate conversion to the TV's native frame rate is trivial. And 60p doesn't take much more bandwidth than 30i with MPEG 2 compression. They missed out on a chance to eliminate interlaced video.
  9. Banned
  10. Originally Posted by sanlyn View Post
    They also missed out on a chance to bypass the majority of TV and player owners around the world who would not be able to watch 20 minutes of non-interlaced commercial advertising for every hour of non-interlaced broadcasting. I can only imagine the vast cost of conversion for public and private concerns.
    Nonsense. First, you needed a new TV to view HD broadcast as HD. For downscaling to SD it's easy to interlace a progressive source.
  11. Banned
  12. Nobody with an old interlaced analog TV can watch digital broadcast without a converter box that converts 1080i or 720p to 480i. That box could just have well converted 1080p to 480i. So once the decision to go with MPEG 2 digital broadcast was made there was no need for interlaced HD.
  13. Unfortunately there was no studio interface standard for pushing around 1080p60 uncompressed until 2002 (SMPTE 372M). It's still a massive amount of data and bandwidth today, never mind with the technology of 15 years ago.
  14. And 15 years ago computer power was doubling every 12 to 18 months. If they had the ability to handle 720p60 or 1080i30 all they had to do was wait or year or two and they could handle 1080p60.
    Remember, they were picking the broadcast standard that will likely be stuck with for the next 40 or 50 years. Not a 1 year consumer electronics cycle.
    The original date to switch to DTV only was December 31, 2006, but it was delayed a few time times before it actually took place on June 12, 2009, so even choosing 1080i with lower technical requirements, it took a while to get broadcasters and the consumer electronics industry ready, never mind the public.
    The Federal government wasn't happy about needing to wait. They wanted the lower half of the the VHF TV spectrum freed up so it could be auctioned off to other parties.
  16. They could have simply defined the standard as 720p and 1080p at various frame rates. Then let the hardware catch up to 1080p60 with time.
    There is a reason for 1080i. Wikipedia says this: "The ATSC specification also allows 1080p30 and 1080p24 MPEG-2 sequences, however they are not used in practice, because broadcasters want to be able to switch between 60 Hz interlaced (news), 30 Hz progressive or PsF (soap operas), and 24 Hz progressive (prime-time) content without ending the 1080i60 MPEG-2 sequence."
    Wikipedia's ATSC page also goes on to say "The new standards supports 1080p at 50, 59.94 and 60 frames per second; such frame rates require H.264/AVC High Profile Level 4.2, while standard HDTV frame rates only require Levels 3.2 and 4, and SDTV frame rates require Levels 3 and 3.1."
    So broadcasters have the option to use 1080p60 if they implement subchannels using H.264. I think the primary has to be MPEG-2.
  18. Originally Posted by usually_quiet View Post
    And they could have done the same 1080p60 (like the have done with 720p60). Stations and consumers that couldn't afford 1080p60 could have used 720p60 until costs came down.
  19. because many tv series do not finish in exactly 30/60/90/etc minutes. so they employ time expansion or compression of the video's telecine cadense pattern at the field level. with interlace, its all "i"'s, so its not necessary, but with film (PPPii) it is. many tv series and movies broadcasted are done this way and is why they are not always properly restorable back to 24p.
    VHELP's - Sample Clips [last: 12.29.06],
    my YouTube videos
  20. How do you think broadcasters that currently use 720p60 do their time compression? With 720p60 and 1080p60 you can throw out p's the same way you throw out fields with 1080i. There's no difference in that.
  21. that is true, didn't think about it that way.
    my YouTube videos
