  1. Just converted a gazzillion mkv to mp4 and I noticed the default audio settings:
    This is not mono is it? - I dont want to do them all again
    2.0 is stereo (or dual mono if that was the source.) However, you may be destroying your sound just as effectively with heavy dynamic range compression.
    Edit: Can't you tell when you listen whether it's stereo or not?
    You should have found a solution to whatever your problem was that did not require this, even if it cost money. Plenty of devices exist that can play MKV files. Such a conversion should not have been necessary unless you're married to iTunes or some kind of Apple device.
  4. Originally Posted by smrpix View Post
    Not watched/listened to any yet - but im fine with defaults proving it is stereo
  5. Member DB83's Avatar
    Are you real ?
    No one converts masses of files without watching/listening to any of them. If they are not up to your expectation then you only have yourself to blame.
  6. Member bendixG15's Avatar
    Are you real ?
    I don't so I'm not real either ..... we all have a diferent drummer ..... Happy Holidays to you all ..........
  7. Originally Posted by DB83 View Post
    Are you real ?
    Used Mkv2mp4 which coverts a batch of 20 videos in as many minutes
    Gazillion was a slight exaggeration )
