    Dec 2013
    Canada, BC
    EDIT: SOLVED Post #3 For people with (RT) Invalid array index. Array is empty - Line 35926 Error read my EDIT in post #4
    Ok I've been at this for days, I've been lurking on this site forever trying to find my answer. And when I think I found the answer it doesn't work.
    I have .mkv episodes of anime that have .ass subtitles within the .mkv. I'm trying to convert the .mkv with the subtitles to a Blu-ray movie disc(BD-MV) that will be playable in most blu-ray players. It must be a proper BD-MV folder structure that the player will recognize as a regular blu-ray movie. Cause the player in question is old and I'm pretty sure it doesn't play data disks or usb sticks. I can't get the model number at the moment for reason's I don't want to get into.
    Everything I tried does not play the subtitles. Even when I convert .ass to .srt.
    I don't mind if they are soft coded subtitles or hard coded subtitles as long as the blu-ray player will recognize the soft coded subs.
    With hard coded subs I don't want to add another encoding step from like: mkv > mkv+hardcode subs > .mt2s/BD-MV
    I want to directly encode from: mkv > .mt2s/BD-MV+hardcode subs
    If anyone can help with what would be the best way to go about this, I've tried these programs so far:
    SubtitleCreator
    ImTOO Blu-ray Creator 2
    Avidemux
    tsMuxerGUI
    multiAVHD
    Hybrid
    dsrt
    ripbot
    handbreak
    Imtoo blu-ray creator wouldn't recognize .ass files so I converted it to .srt. I added the subtitles in then encoded it to a BD-MV iso so I could test it on my computer without wasting a BD-R. So I mounted the iso with daemon tools and played the BD-MV iso with arcsoft total media theater 6 and ps3. The audio went out of sync half way through and no subtitles showed up in the submenu-subtitles.
    I've tried various methods with other programs sometimes the player would show subtitles 1 - english activated under the submenu but nothing would show.
    I am subscribed to this thread by email so I will maintain discussion, thank you.
    Here is the media info for an episode:
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 551 MiB
    Duration : 24mn 13s
    Overall bit rate : 3 180 Kbps
    Encoded date : UTC 2013-09-01 02:11:14
    Writing application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
    Writing library : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 24mn 13s
    Nominal bit rate : 3 072 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.500 fps
    Original frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.063
    Writing library : x264 core 120 r2120 0c7dab9
    Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3072 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=6144 / vbv_bufsize=15360 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 24mn 13s
    Channel count : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Delay relative to video : -83ms
    Default : Yes
    Forced : No
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Default : Yes
    Forced : No
    Dec 2013
    Canada, BC
    shameless bump, i still haven't been able to figure this out.
  3. Perhaps give multiAVCHD another shot. It'll give you a menu to select between your titles (episodes) as well as selecting subtitle. You can also choose to have the subtitles forced to be shown. I made this youtube video to show how.
    http://www.youtube.com/watch?v=Tb1DlXiXr3U
    PS: I think you need to have Java installed in order to convert your .srt to PGS
    Dec 2013
    Canada, BC
    Thank you for taking the time to help.
    I followed your video perfectly, when I click start and after it finishes I get an error: (RT) Invalid array index. Array is empty - Line 35926
    Then I click "OK" and the program crashes.
    I then check to see if it outputted the Blu-ray.
    It made the file structure but it didn't make the .m2ts video file.
    Everytime I try to use multiAVCHD with these mkv files I get that error.
    So I tried it with .srt instead of .ass and got the same error.
    I tried to convert my .mkv with Haali gdsmux.exe then compiled with multiAVCHD and still got the same error.
    I searched google for that error and I couldn't find any solutions.
    Does anyone know what's wrong your should I post in a bug/technical help forum?
    EDIT: I followed these steps in post #5: https://forum.videohelp.com/threads/336204-multiAVCHD-error?highlight=header
    and they fixed my error!
    I can play subtitles fine now and the blu-ray structure works with my players. The only thing that sucks is I have to mkvmerge all my episode which is a bit tedious to do one by one, but at least it works haha
    thank you
  5. multiAVCHD is no longer developed so posting probably won't help.
    Try using your assets from a very simple file structure like "c:\MyVideos" and output to something simelar like "c:\Output". I think I recall something similar using ..\Documents\... or perhaps ..\Desktop\.. Anyway one of those directories Windows try to rename to something completely different in my language. I recall it didn't make the m2ts file or it was empty.
