Hi,
Im using Vegas 12 pro to endcode to MPG2 for the purpose of making DVDs.
I have been using Neat Video Pro to take away some of the grain in my footage, which is does quite well,
however I am getting some random split second pauses or glitches in my final output file.
Neat Video forum is suggesting that there maybe an issue with the codec.
Can anybody recommend a 3rd party MPG2 Codec that is as good as Mainconcepts MPG2 that will install
into Vegas, so I can do some more testing.
Cheers
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
I think they are suggesting the problem is with the input codec, not the output codec. What's your source?
(And there's really nothing wrong with Mainconcept these days) -
The source file are Image sequence JPGs created by software attached to a Frame By Frame scanning Unitfor 8mm and Super8 projector Films. The quality is quite good, but a bit grainy, hence why i'm trying to slightly clean
the overall presentation up for all of my clients.
I have very few settings to adjust the output. i could try Tiff seq or .MOV as an output and giver it a try
these are my only output options.
Thanks for pointing my brain in that direction.
I'll do a few experiments
cheers
ScottWhy is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system. -
That's really interesting. Pure conjecture here, but there may be some issue with the way Vegas and Neat reference and compare frames that makes an image sequence problematic.
Maybe try rendering a short section to an uncompressed video file without applying Neat, import that clip into Vegas and try applying neat to that clip. See if it makes a difference.
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Alternative to Shark's Codec Pack?
By MilesAhead in forum Video ConversionReplies: 3Last Post: 3rd Aug 2010, 17:55 -
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 20:31
