Results 1 to 12 of 12
    Hello,
    I recently purchased a TV tuner card for my PC and have managed to record something from one of the HD channels.
    When navigating to the file, it became apparent that it is a MPEG-2 TS file.
    Whilst this would not normally be a problem (since I could just get codecs or play it back through the PVR software), I do need to be either AVI, MP4 or MKV so that I am able to play it back on my network player.
    I attempted to change it to MP4 (H.264) by importing it into a video editing software, which then re-encoded it and rendered it out, but that resulted in the picture quality becoming quite poor. So I'm back to square one.
    I just want to be able to maintain the quality of the video/audio and am not worried about filesize at all. (the original is about 3GB).
    Can anyone suggest what to do?
    Thanks~
    Apologies, but I believe I have posted this in the wrong section.
    I will re-post this in the relevant section now.
    What did you connvert with?
    Try vidcoder or handbrake and use the high profile preset.
    NOOO. Do not cross post in several sections. This section works fine.
    Well I'm actually a complete novice when it comes to all of this, so I just used Adobe Premiere Pro to export it as a new file. Again, a complete novice so that probably wasn't a good idea.
  6. You don't need to convert it as your recording is already in H264 format - only ts container is recognised as being MPEG-2 but if you check with MediaInfo it shows correct and full info. You may remux your ts into mp4 with MP4Box or mkv using MKVToolNix.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep, that sounds smarter. You just add the ts file in mkvmergegui / mkvtoolnix, make a new mkv(takes a few minutes) and hope it works on your network player.
    Hmm, tried the file in mkvtoolnix and it displays warnings such as: 'No valid AAC header found. May cause video/audio desyncronisation'.When playing the new MKV file it doesn't have any audio at all...
  9. It's how BBC broadcasts... What a PC player do you use? May you post (html formatted) log from MediaInfo of your mkv and ts file?
    (Will try to post that again, something went wrong)
    I use VLC player on the PC.
    Here is the info from MediaInfo...(tried to set it as HTML formatting but it went all strange, so hopefully this is ok)
    Original TS File:
    General
    ID/String : 1 (0x1)
    CompleteName : Hidden
    Format : MPEG-TS
    FileSize/String : 3.89 GiB
    Duration/String : 1h 2mn
    OverallBitRate_Mode/String : VBR
    OverallBitRate/String : 8855 Kbps
    Video
    ID/String : 201 (0xC9)
    MenuID/String : 17604 (0x44C4)
    Format : AVC
    Format_Profile : High@L4.0
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 4 frame2
    CodecID : 27
    Width/String : 1920 pixel3
    Height/String : 1080 pixel3
    DisplayAspectRatio/String : 16:9
    FrameRate/String : 25.000 fps3
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bit3
    ScanType/String : Progressive
    colour_primaries : BT.709
    transfer_characteristics : BT.709
    matrix_coefficients : BT.709
    Audio #1
    ID/String : 202 (0xCA)
    Format : AAC
    Format_Profile : LC
    MuxingMode : LATM
    CodecID : 17
    Channel(s)/String : 2 channel2
    ChannelPositions : Front: L R
    SamplingRate/String : 48.0 KHz
    Compression_Mode/String : Lossy
    Video_Delay/String : -1s 20ms
    Language/String : en
    Audio #2
    ID/String : 206 (0xCE)
    Format : AAC
    Format_Profile : HE-AAC / LC
    MuxingMode : LATM
    CodecID : 17
    Channel(s)/String : 1 channel1
    ChannelPositions : Front: C
    SamplingRate/String : 48.0 KHz / 24.0 KHz
    Video_Delay/String : -710ms
    Language_More : Visual impaired commentary
    Text
    ID/String : 205 (0xCD)
    Format : DVB Subtitle
    CodecID : 6
    Video_Delay/String : 3s 598ms
    MKV file:
    General
    UniqueID/String : 249204416680309145701147515075790459455 (0xBB7B065BA3DA110DA8B2A6FE15F5523F)
    Format : Matroska
    Format_Version : Version 4 / Version 2
    FileSize/String : 3.63 GiB
    OverallBitRate/String : 8 266 Kbps
    Encoded_Date : UTC 2013-12-12 16:32:14
    Encoded_Application : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec 1 2013 17:55:00
    Encoded_Library/String : libebml v1.3.0 + libmatroska v1.4.1
    Video
    ID/String : 1
    Format : AVC
    Format_Settings_RefFrames/String : 4 frames
    CodecID : V_MPEG4/ISO/AVC
    Width/String : 1 920 pixels
    Height/String : 1 080 pixels
    FrameRate_Mode/String : Constant
    ColorSpace : YUV
    BitDepth/String : 8 bits
    Default/String : Yes
    Forced/String : No
    Audio
    ID/String : 2
    Format : AAC
    Format_Profile : LC
    CodecID : A_AAC
    SamplingRate/String : 16.0 KHz
    Video_Delay/String : 6ms
    Language/String : English
    Forced/String : No
  12. Your problem is mixture of AAC-LATM / HE-AAC, and that matroska doesn't handle them well. Easy option is to convert audio to AC3 with i.e. TAudioConverter - download latest beta version here. It handles audio in ts container but you need to show all files when adding your into TAC. Don't forget to check sampling rate (should be 48 kHz or "original") in codec setting.
    BTW: MPC-BE plays Freeview recordings without a problem.
