  1. Member MI6's Avatar
    I have video with "EWC2" extension and I can't open it in Sony Vegas, only audio is appear on timeline.Maybe I have no codec instaled on my PC.Please help?
    QUALITY HAS A NAME
    According to multiple googled sources, EWC2 is Edius cached waveform files, meaning they are most likely the picture of the audio waveforms. Not likely to have any video.
    Can you actually play the audio?
  3. Member MI6's Avatar
    No, only audio but acording to how is in "MB" one clip there should be video too.
    QUALITY HAS A NAME
    Two things to try:
    See if changing the file extension to .mts makes any difference.
    If not, download Mediainfo and see what it tells you is in the file. Use tree view.
