ID:	21890why does virtualdub say error on ACM audio if ACM codec is installed. I installed it already ,but vd says its missing
    http://w1funurl.webs.com/ACM-missing.jpg
    how do I fix this ?
    Attached Thumbnails Click image for larger version
  2. Member Budman1's Avatar
    Be sure you have the ACM codecs installed since VirtualDub uses ACM types for audio and VFW for videos. They can be downloaded at http://gral.y0.pl/~fcchandler/index.html\ . You should see them present in the audio
    compression selections list in VirtualDub and your uninstall list as well. These are also 32 bit codecs so make sure everything is 32 bit including Virtualdub.
    Another good site to explain this procedure in detail is http://www.dedoimedo.com/computers/virtualdub-codecs.html
    Name:  ScreenHunter_45 Dec. 11 08.15.jpg
    Name:  ScreenHunter_45 Dec. 11 08.16.jpg
