  1. Member khodam's Avatar
    Dear users,
    I'm developing an application which streams live source via RTP. Currently I'm using MPEG-2 Video Encoder for video compression and everything works fine. I want to use H264 encoding in my live stream. I searched a lot, downloaded some H264 encoders and unfortunately none of them worked correctly.
    For example I used X264vfw, but it shows "output frame buffer too small (size 513/ needed 17576)" error.
    And some encoders causes GraphEdit to crash.
    Can you just name a H264 Encoder which works fine with live source?
    Thank you very much
    Best wishes
  2. vanished El Heggunte's Avatar
    IIRC, Mainconcept has some standalone DirectShow H264 encoder.
    LEADTools certainly has one as well.
    RadScorpion has a freeware filter, however it hasn't been updated in years
  3. Member khodam's Avatar
    poisondeathray:
    I downloaded direct264 but it had x264.exe and VSFilter which merges video and subtitle. It doesn't have h264 video encoding DirectShow filter.
    El Heggunte:
    Actually I'm seeking for free h264 encoder. I'd been tried RadScrorpion's but it doesn't work unfortunately
    Thank you for commenting guys
    I'll be happy if you recommend me h264 DirectShow filter
    Best wishes...
  4. vanished El Heggunte's Avatar
    Selur,
    the nickname of the owner of that blog is RadScorpion.
  5. oh, missed that
