WinDV can split DV files based on time stamp when capturing.
I want to capture the tape to a single file, and then do exactly that splitting-based-on-time-stamp later. Is there any software that can do this? Must be lossless (video, audio, metadata, everything). Must be frame-accurate. Must let you specify a sensible filename format for the output.
It would be an advantage if it let you preview the splitting before it did it, and even better if it then let you remove certain split points before carrying out the splitting.
Any ideas?
Cheers,
David.
I wouldn't be surprised if enosoft DV processor can do it. Avid Media Composer does for sure -- but that's not always practical.
try this one: http://scenalyzer.de/scenalyzer.zip
There was Scenalyzer Live that captured by scenes and scenalyzer that was splitting scenes already captured DV avi, it was a bit confusing, because same name, but try it. -
Thank you _Al_, that's perfect.
I think it's more robust against timecode glitches than WinDV is. With WinDV, on damaged tapes, I get single frames split out in the middle of scenes with random dates (1980, 2027, etc!) which is what has forced me to capture full tapes in the first place. I think scenallyzer is keeping these errant frames within the scene and avoiding unwanted splits.
Cheers,
David.
DVB-T capture soft with timestamp
By kamisama in forum DVB / IPTVReplies: 0Last Post: 31st Mar 2010, 05:11 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
Interrupted WinDV Capture...Now I can't play the AVI file.
By ione in forum CapturingReplies: 11Last Post: 18th Oct 2009, 08:52 -
lost timestamp on tod files
By mpunt in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2009, 15:49 -
split/join avi files without recompression
By Jan G. in forum EditingReplies: 3Last Post: 20th Dec 2008, 13:54
