  1. I have videos from a dozen sources so I use AVI which plays all of them but how can I combined some of the hundreds of videos I have from so many sources.
    It's probably easiest with something like freemake video converter, load all video files, at top right click join video, save/convert as a new avi,mp4,etc.
  3. I'm new here so I might be in the wrong forum. I'm not trying to convert, I'm trying to edit so I can combined maybe a half dozen video clips into one video clip. Will this converter do that are am I in the wrong forum?
    Yes, it will join and convert.
    If you are looking for just to join without reconverting must all your files have EXACT same video properties.
  5. The videos that I'll be joining will have the same video properties because of the time frame. I want to join videos from one camera but not from the next camera because there could be a year+ apart and the same with my webcam videos, so I just need to join video that will have the same video properties and then play them with AVI
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    I see.
    You can use virtualdub or avidemux to join/append files. But you can only open/load/append one file at a time....if they aren't named like video001.avi, video002.avi, video003. avi, etc. Under video and audio choose copy/direct stream copy to avoid conversion.
    I can't say that I know that many other free and simple editors that can join without reconverting. Maybe video to video converter under tools->join video.
