Hibeen using the forum for a few years but my time with a question has come, so I only registered now. Sorry for that guys
That said my problem is: I have a captured FLV from a streaming website and when I have the completed file the timeline shows something like 6 days, 23h, etc when it actually has 5 or 6h. I can solve that by using FLVextract and then join the files together with mkvmerge.
After this the video and audio length are okay but the audio is coming early so I had to go into mp3directcut to had 9.25s to the audio file and join them together again.
Things were going fine until almost the end of the video. This is when I face the following: video goes normally and audio too, a still picture shows up (part of the captured stream, all fine here including length) and then the audio delay has to be shifted to 7.8s so everything matches.
As the video (avc1) has keyframes I can't really cut and paste the video to add the extra 1.5s to the still image. The ideal is to at the precise point things doesn't match anymore I could shift the audio. A problem surfaces, the audio gap between part1 and part2, and that's when I tried to copy audio from part1 to part2 but everything gets messy and I still have delay.
The goal here is to not re-encode the video/audio or at least not the video.
Here is my file info:
Any help? I used avidemux/virtualdub/video to video/mp3directcut/yamb all with direct stream copy to not re-encode the video/audioGeneral
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 1h 29mn
Bit rate mode : Constant
Bit rate : 794 Kbps
Nominal bit rate : 1 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.000 fps
Minimum frame rate : 29.425 fps
Maximum frame rate : 30.296 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.029
Stream size : 511 MiB (85%)
Tagged date : UTC 2013-12-05 02:35:21
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 29mn
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 82.3 MiB (14%)
My experience with stream capture has been that the sync can go in and out, depending on a lot of circumstances. A good way to see this is turn on the timecodes checkbox in FLVextract and scan thru the list that is saved. You will probably see that the codes vary but not in a constant .033/034, .040, etc. for normal frame rates.:
# timecode format v2
0
0
33
67
100
133
167
200
234
234
234
300
334
367
It can be a real bear trying to fit pieces in when audio and video drift badly on a captured stream. There may be a way to do this in one move, but without re-encoding its very hard. Good Luck! -
Why extract the streams before remuxing into an MKV? You can simply open an FLV file with MKVMergeGUI and remux it, and if you do it that way any audio delay should automatically be used by MKVMerrgeGUI. Likewise if you simply append the original FLV files it should work. Any resulting gaps due to each file having a different audio delay or because the audio and video streams are of slightly different lengths should be handled correctly.
I say "should" as I rarely work with flv files, but that's how it seems to work when remuxing/appending MKV/MP3/AVI with MKVMergeGUI so I'd assume the same applies to flv. It won't take long to test and it'll save you a lot of hassle if it does.
Syncing MKV audio (Problem: FPS.)
By PonyoBellanote in forum Video ConversionReplies: 7Last Post: 10th Nov 2013, 17:30 -
Video and Audio Syncing
By pboong in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2013, 09:09 -
Audio syncing problem...
By Huntr777 in forum MacReplies: 3Last Post: 1st Aug 2011, 16:30 -
Newbie here needs help syncing audio to video
By blackwaterstout in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2010, 07:19 -
Visually Syncing Audio with Video
By gonzalu in forum EditingReplies: 11Last Post: 17th Mar 2009, 19:18
