Thread: SONY codec ?
  1. Member Tafflad's Avatar
    I have previously used an ADVC300 for all my VHS tape captures ... PAL S-VHS
    I carry out no processing just a straight capture using WINDV, why do the files show as being created using SONY DV codec ?
    Why would it use a SONY codec ?
    If I look at MediaInfo for the files they all show the following:
    Format : AVI
    Commercial name : DV
    Format profile : OpenDML
    Duration : 16mn 28s
    Overall bit rate mode : Constant
    Overall bit rate : 30.4 Mbps
    Video
    Format : DV
    Codec ID : dvsd
    Codec ID/Hint : Sony
    Duration : 16mn 28s
    Bit rate mode : Constant
    Bit rate : 24.4 Mbps
    Encoded bit rate : 28.8 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.357
    Time code of first frame : 00:00:00:03
    Time code source : Subcode time code
    Stream size : 3.31 GiB (95%)
  2. MediaInfo always says "Sony" for the "dvsd" fourcc.
  3. Member Tafflad's Avatar
    OK .. in earlier post I was chastised for using the inferior SONY codec
    Found out that the ADVC300 appears to computer as if it is a Sony MiniDV camcorder's IEEE1394 interface. And its IEEE1394 output stream looks like a MiniDV camcorder output.
  4. Originally Posted by Tafflad View Post
    My guess is you're using Windows' built in DV decoder to view the video.
    Yes, the ADVC300 has a DV encoder chip. It sends a DV A/V stream to the computer via firewire. WinDV just takes that stream and wraps in in a AVI container.
  5. Member DB83's Avatar
    For a giggle or two (not much else to laff about today) I did a few tests with my ADVC.
    First, I did two 'captures' with WinDV. The type-1 capture just shows 'DV' in mediainfo. Procoder identify this as 'LAV (dvcp)'
    The type-2 'capture' only shows the 'hint' and Procoder identify this as 'LAV (dvsd)'
    I then did two similar captures using Ulead DirectShow and these produced the same results as above.
  6. Member Tafflad's Avatar
    Strange then .... I am only doing a capture no processing, no conversion .... yet everyone of my files is tagged as SONY DV
    Are you using W7 ? ... could that be the difference
  7. Member DB83's Avatar
    You missed the critical difference. Only type-2 DV files have this. The type-1 file does not.
    And jagabo confirms my earlier suspicion(PM). Mediainfo does not always get it all right. I sense a little paranoia creeping in. I appreciate you want to get it right at the third time of asking.
