Results 1 to 10 of 10
  1. So i want to backup my FRIENDS Blu rays,. but DVDFab only lets me select one episode. How can i select multiple episodes?
    Also there seems to be more than 12 episodes at 22minutes each,. but there should only be 12.
    Copy the entire disc?
    Or do you want to extract/convert each episode?
  3. Originally Posted by Baldrick View Post
    There doesn't seem to be a "Copy entire disc" option. It selects one "Track" for you and won't let you select any more.
    Did you select Copy and Full Disc?
  5. Originally Posted by Baldrick View Post
    Attachment 21628
    Thanks for the response,. mine is the very newest version,. so i looked around for ages and could not find the full disc copy bit. You have to click on the big picture at the side and the options will come up lol.
    Silly me.
    http://i5.imageban.ru/out/2013/11/29/2e403b4f6e599060b8701c95f7883eea.jpg
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    They change the layout way too often....
    I prefer anydvd or makemkv.
  7. Originally Posted by Baldrick View Post
    I heard everyone talk about DVDFab,. so i've already paid for this lol. Seems good, made a perfect copy of Pacific Rim, and yet to see the quality of a box set Disc shrunk to 25gb is like (Usually with all the episodes the discs are 50BD and full)
    Do you know of any good software that will author a standard .mkv or .avi file into a blu ray disc that will play on any Blu ray player?
  8. Originally Posted by Baldrick View Post
    Thank you, i'll give them a go. I tried using some weird Tx thingy yesterday and it didn't work.
    Someone suggested MultiAVCHD so once i've done this blu ray i'm going to try that. If that doesn't work i'll try the one you suggested. (BdRebuilder doesn't open on my PC for some reason)
    Thank you
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    bdrebuilder requires some other software installed. You can run http://www.jdobbs.net/freeware/inspect.exe to see if you have everything installed.
    Or just try the other software.
    I think the simple but adware supported freemake video converter can output blu-ray from avi,mkv, etc also.
