Thread: Win8-8.1
    I have Win8 in my computer, 1tb HD, i7 Intel, 8G ram, I am
    considering upgrading to 8.1, before I do, I thought Id throw
    it out to the pros. Bad or good idea, if so is there a
    compatibility app that should be downloaded?
    Thanks in advance,
    Jim Durkin
    James Durkin
  2. You should definitely do it, many things were improved in 8.1, but there's a catch if you upgrade through the windows app store; should you ever need to re-install windows, you'll have to re-download it. It's best if you can get the ISO to make a disc, I just don't know if the trick is still active.
    Thank you very much for the tip.
    James Durkin
    Thanks in advance,
    Jim Durkin
    I listed some pros here.
    I know from personal experience that some firewall and antivirus programs that worked with Windows 8 were incompatible with Windows 8.1. I guess most have been patched now or there is a new version available that is compatible with Windows 8.1, but Google yours to make sure.
    There is a compatibility list: http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/Home but not much has been added yet.
