Hi
how can I change a file that is yuy2, into a file uyvy?
with ffmpeg is possible only in rawvideo codec, but possibly I would like do with all types of file .avi YUV.
Is possibile this?
and when incour in yuy2-->uyvy I get a loss of quality?
thanks
Not possible; those fourcc's only apply to uncompressed video and describe the byte arrangement . If the video has some other type of compression e.g. mpeg2, mjpeg, etc... it doesn't apply
VirtualDub can convert YUY2 to UYVY. There is no loss of quality going from YUY2 to UYVY -- all it's doing is changing the order of the subchannels from YUYV to UYVY. Of course, if you encode with a lossy codec you'll get a loss of quality. And the decoder for that lossy codec may change the order back to YUY2 on decompression.
I use virtualdub with the enahncement YUY2-->UYVY and then I use UtvideoYUV422(bt.601)ULY2 codec but strangely the nle don't recognize the output as uyvy, even then Ut teorically can output in uyvy mode
UT Video is a form of lossless compression, not uncompressed video . The NLE "sees" UT Video before it's uncompressed . Again, those fourcc's only apply to uncompressed video . That is why ffmpeg can only do it with "-vcodec rawvideo"
I already tried to answer your questions in your other thread, but it still doesn't make sense ?
https://forum.videohelp.com/threads/360445-from-mxf-to-uncompressed-avi -
The editor and the decoder negotiate a colorspace. The editor tells the decoder what colorspaces it prefers and the decoder supplies whichever of those it supports. So if the editor says "I prefer YUY2, YV12, and RGB, in that order" and the decoder supports UYVY, YUY2, and RGB as output, it will decode to YUY2 -- because the editor said it preferred that.
My source is YUV or YUY2?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2013, 12:25 -
YUY2 vs RGB24 vs Y800
By 201flyer in forum Software PlayingReplies: 40Last Post: 28th Apr 2011, 06:11 -
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 10:21 -
How to take stream in -> decode to file (UYVY)
By zakeboy in forum Video Streaming DownloadingReplies: 5Last Post: 28th Aug 2009, 13:30 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 08:07
