Hi folks,
I'm the type that always needs to know why/how things work. I don't just power up a computer and it magically does what I want, instead I learn c++, make apps and see how it works.. (but that's off topic!!)
so here is where I am:
I've got a 3dtv, updated my computer to play blu-ray and watched 3d movies on either the pc or the ps3.
I've researched and learned that 2 cameras are used for the left/right eye.
I've created a short animation that uses 2 cameras and created a sbs movie(I switch the mode on the tv to watch sbs as 3d)
there is more to it than that...
My question is how to author the movie as a 3d film, rather than sbs?
the only thing ive found is roxio mydvd that can do the trick, but there`s a $50 price tag with that and its a tad expensive seems as im only playing/learning..
is there any open source programs out there, as so far, I've found nothing?
thanks for any reply's...
Results 1 to 10 of 10
You'll probably want to do a little background research on it anyway, so I'd suggest you look at my past posts on "stereo3d" or "stereo 3d" or "stereoscopic".
In them, you'll find that there is NO opensource (or any other kind of freeware option) apps for doing what you want. Probably for the simple reason that 3D is still quite a niche market (much to my chagrin) and the technology involved is mired in patented/proprietary/commercial foundations as well as being very complicated (certainly at least for the mvc encode/decode and TS packet interleaving/deinterleaving steps).
There are about 3 or 4 commercial apps that will give you stereo3D-capable discs (with varying degrees of cost & features & quality). The Roxio one you mentioned produces ONLY (less than) Half-quality SD SbS 3D material DVDs (not full nor half-quality HD 3D material on BDs) and it is the cheapest of the bunch, so if you cannot afford that one, you certainly cannot afford the better apps. As mentioned before, Vegas Pro (v10-12) can do full quality (true MVC/SSIF) 3DBDs. It is the best option quality-wise available to regular consumers, but it isn't cheap either. And if you were to go into PRO 3DBD authoring, the price jumps at least ~6x (into the multiple thousands).
If you were up for programming your own opensource app, I'd gladly let you know what I know about the format.
Scott -
thanks for your quick replies peeps..
at 600, it makes mydvd look cheap. I have seen a YouTube video showing how to do it with mydvd hd. that said, research online indicates the cheaper packages usually give poor results... anyone used roxio mydvd hd?
to combine the left right images, I used sterio 3d maker, by the way..
thanks again for your replies.. -
UPDATE: Things may start to get easier to do for 3D (particularly 3DBD), given the latest software tool additions: FRIM MVC Encoder/Decoder, updated beta TSMuxer, and Blu-Disc Studio...
Gonna have to try these out in the upcoming weeks, though still waiting on a Win7/64 box, so it might be longer. Even if it does work, it would likely not be the way to go for newbies (AVISynth scripts, CLI tools, etc required). But it bodes well for the future.
Scott -
I have to be honest, I did spot mvc enc/dec and tsmuxer during my searches. The names gave me flashbacks of learning about vcd's, before dvd became popular.. Maybe its worth the challenge of figuring out such tools, instead of being lazy and looking for open source suites, before they become available.. hehe..
Still, I do enough crazy stuff, that folks who know me have named me "the mad professor" -
Pinnacle Studio 17 and PowerDirector 12 can author 3D Blu-ray in multistream, sbs and anaglyph. Both also allow 3D Menus. I own both of these, and right now PowerDirector is the better of the two because it is far more stable. Studio is buggy, buggy, buggy!
Brainiac -
hmm.. may look at director as I use cyberlink for playback.
cheers brainiac -
Just wanted to check up on this. Did you find a good solution that could take your SBS file and make a 3D Blu Ray out of it?
Rip Blu-Ray and re-author
By whoisquilty in forum MacReplies: 5Last Post: 13th Dec 2012, 20:04 -
Encoding Blu-Ray 2D Into 3D Full SBS
By x264Encoder in forum Blu-ray RippingReplies: 3Last Post: 27th Jan 2012, 11:38 -
simple sw to re-author Blu Ray
By Oktober in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Jul 2010, 04:24 -
Worth it to re-author SD video from miniDV source to Blu-Ray?
By jg0001 in forum Authoring (Blu-ray)Replies: 5Last Post: 27th May 2010, 12:55 -
Author TS Stream to Blu Ray - Always need to be re-encoded?
By steve99999 in forum Authoring (Blu-ray)Replies: 12Last Post: 16th Aug 2009, 06:12
