Hi Folks,I have downloaded a rock concert from online in to my hard drive, it is in MKV Blue ray format but my LG blue ray that comes with the smart 3D LED TV, does not play the audio. The video quality is good but the warning on screen says"does not support audio format". Now I need to know what format should I convert in order to listen the audio too and what software can I use. By the way, any my LG player plays most of the files except MVI.
Please let me know as am frustrated with this.
Thanks.
Try converting to AC3. You have violated our policies with your post so your thread will likely be closed soon, but if you can act quickly, instal MediaInfo and open your MKV file with it. Cut and paste the info from MediaInfo about your file to get more specific suggestions, that is, before a moderator notices your reference to downloading and closes this thread.
Sorry about that, it was my first time, though I tried searching where to post it but ended up here. I will try doing it correctly next time. Thanks for the good suggestion. Regards.
Underworld-Awakening Blue-Ray Audio?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 20th Jun 2012, 10:18 -
Blue Ray Convert 4:3 To 16:9 Possible?
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 28th Jul 2011, 17:02 -
Blue Ray convert to HD MPG
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 23rd Oct 2010, 20:48 -
AudioDVD to a format for blue ray?
By alc112 in forum Blu-ray RippingReplies: 1Last Post: 28th Mar 2010, 06:40 -
Audio out sync using Sony BDP-S350 Blue-ray Player
By justmehere in forum Video ConversionReplies: 6Last Post: 26th Jan 2009, 18:58
