Anyone familiar with the creation of the video effect in which an album cover is opened to a page with picture stills followed by a zoom in to a still and the start of a video.
Is there a special effects software add on that can be used to create this effect??
I am a pinnacle studio user
Typically it's done in after effects
Pinnacle studio might have a few problems with this because I don't think you have a composition camera or z-depth (3d space) , but you might be able to simulate the effect or getting close by scaling layers up . (It depends on how simple / complex or how you want it too look exactly )
If you don't feel like doing it from scratch (There is a bit of a learning curve), there are "templates" or pre built projects that have some degree that you can customizey and "placeholders" where you just replace with your own images and videos on vendor sites like videohive.net, or revostock.com . I don't think they have any specifically for pinnacle studio - again mostly after effects for something like this
what is the best software for mixing video and images with special effects
By ukcalibrauk8 in forum EditingReplies: 0Last Post: 24th Aug 2011, 02:00 -
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 10:12 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
Which video editors do special effects like pan, zoom, speed ctrl?
By tluxon in forum EditingReplies: 1Last Post: 21st Jan 2010, 16:27 -
which applications can be used to create video special effects?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2008, 07:26
