Hi!
First, sorry for my bad english.
Im trying to extract DVB sub files from a .TS capture from an spanish IPTV. ProjectX detect the subs like a "DVB sub" (not teletext one). Then, the program extract the SUP file but when I try to convert to SRT or open the file to see the subtitules, I can check that the file has many mistakes. Its like when the program capture the line, doesnt erase the previously one. Every subtitle line has the lines before there, so when I try to see the line '10' its impossible cause there are 10 lines one over other.
I think its better to check by yourselves, so then...
The .TS capture:
https://mega.co.nz/#!HN0gDRzC!St8dJWBFhFPp1jbjhytHsAcJ5LB7lA7cr7_bBNn_PKw
The SUP file:
https://mega.co.nz/#!TJ1BBKzC!T38qECGC83zFR2zixQSpGz3-ExVzqE2A9sBLXZ9Oduk
The IFO file:
https://mega.co.nz/#!fcdgHZQZ!Cx2VDmsjwFhXrCXodVMZ72BGVfx4z6c3EMJqvC4Ecgw
Thanks.
Results 1 to 1 of 1
extracting subs problem
By Cabasho in forum SubtitleReplies: 9Last Post: 11th Feb 2013, 13:19 -
DVB Subtitle Extraction ProjectX etc.
By MaxWren in forum SubtitleReplies: 10Last Post: 30th Nov 2012, 17:17 -
extracting subs from mpg
By Kracov in forum SubtitleReplies: 6Last Post: 14th Jul 2012, 22:12 -
MPEG TS recorded from DVB: impossible to extract subs good enough for OCR
By edea in forum SubtitleReplies: 25Last Post: 25th Oct 2011, 12:07 -
ProjectX Audio problems
By hhggzz in forum DVB / IPTVReplies: 0Last Post: 26th Jun 2010, 12:58
