I have a Dell Inspiron 530 that has 8 GB of RAM and a E4500 at 2.2 Ghz. My Blu Ray driver says, "CPU: Intel Pentium D 3.2 GHz or equivalent (Recommended: Core 2 Duo E6600 or higher). Do you think my specs will work with this drive or should I upgrade the processor?
Results 1 to 18 of 18
As long as your system can maintain a burning data rate at around 20 MBytes a sec you will be ok.
Is the processor speed the most important thing when burning to Blu Ray?
Nope,its the burning rate that the system can keep up with,older cpu systems don't have the power to keep up,some cpus at 2.2 ghz dual core are faster than other 3ghz dual core cpus,depends on the architecture of the cpu and system.
Try copying a video file,around 4 gb from one folder to another folder and see how fast the copy rate is,if its lower than 20mbytes per sec then you will need to upgrade your whole system,ideally you want to have at least 50MBPS on a regular hdd.I think,therefore i am a hamster. -
I have a second Inspiron 580s that has a i3 530 2.93 Ghz processor with 4 GB of RAM. I've been debating on which computer I should put my Blu Ray burner.
If you meant 33 MBps that should have taken 2 minutes which is good enough for burning at 4x blu-ray,
Put it on the inspiron.
This Inspiron I have is specifically for non-Internet audio/video projects. So even if it does take awhile to burn a disc I just hit the button on the KVM switch and I can come back to the computer when it's done.
My internal Bluray burner (LG BH14NS40) is is on a lowly Intel E2180 2Ghz core2 with only 2GB of ram and plays BD and burns fine. As you no doubt know you'll need a hdcp compatible graphics card and display to play protected content.
There's not much to do but then I can't do much anyway. -
I became aware of that today. The HDMI port on my Inspiron 580s gives no video. I have a low profile graphics card that allows for dual DVI, but I don't have the cables/monitor set up for that yet. That is pretty disappointing that the Blu-Ray won't play without hdcp compatibility.
Originally Posted by matthewjohn23Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
I have Cyberlink Power DVD that came with the Blu Ray drive. It will not allow me to watch Blu Ray video on my VGA connection. I had no idea that Blu Ray was so restrictive in terms of only being able to see it on a HD monitor or TV. I tested two Blu Rays and only one of them would play in VLC. But honestly I think the viewing experience is actually much better on my $40 Sony Blu Ray Player on my 40" TV.
My old PC is a Athlon 64 X2 4600+ w/ 2GB's RAM, and it has burned numerous Bluray's at 4X just fine.
-The Mang -
The reason I have the burner is for backup purposes and also to read and burn Blu Rays. I don't find watching the Blu Ray on my computer to be particularly inspiring. But I guess I had no idea what type of proprietary stuff was going on with needing HD hardware to play movies on the Blu Ray software.
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 15:26 -
LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
By john8611 in forum DVD & Blu-ray WritersReplies: 11Last Post: 5th Feb 2012, 04:58 -
LG Blu-Ray Burner only burning 2x BD-RE at 1.1x
By Lawbringer in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Jan 2011, 21:24 -
Blu Ray burner help
By dafoe in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Apr 2009, 01:14 -
have a question Im new about blu ray burner
By sdavis in forum Blu-ray RippingReplies: 4Last Post: 22nd Jan 2009, 21:33
