Hello, I have a ton of mp4 files (mostly youtube) that i'd like to split into smaller segments.
Is there a program that will work with the current codec H.264 MPEG-4 AVC to slice and dice these videos up without a lengthy re-encode?
Results 1 to 9 of 9
Video To Video Converter has a file splitter under the Tools menu. The commercial remover is a basic editor. They both give you a preview of the video. They'll work without re-encoding as long as you're happy to split/edit on keyframes.
I haven't used it for MP4 myself (I use MKV) but it'll work with lots of different containers/formats. -
Solveig MM video splitter is a fantastic program for this.
If you want to see what I've done with my videos,
check out my video work on youtube, http://www.youtube.com/user/duhmez/ -
Avidemux cannot cut on exact frames properly for alot of videos. I don't recommend it.
I downloaded & tried this; it was able to cut within 20 frames or so of where I needed it. btw, I used this on a huge video... like 3 hours long. Cut it into about 6 pieces with a bit of MsPaint work to make sure the exact point was cut from piece to piece. It did not re-encode; it was super super FAAASSTT.
I will buy this!
dL'd this, haven't tried it yet.
I'm about to dL this; will try it out sometime.
What about MkvMerge??
I also dL'd this; will try it out sometime and report back results.
Life is very busy right now, but for the fastest re-encode I'd like to see if any of the other programs can beat VideoReDo H.264. -
Any programs which cut without re-encoding are limited to cutting on keyframes and Avidemux is no different in that respect. In order to cut on specific frames a program at least needs to be capable of "smart cutting" and able to re-encode the section of video around the cut point. It's not the sort of thing I've needed myself so I can't recommend any free programs capable of smart cutting. Well there's MKV Cutter for MKVs and Video To Video Converter may be capable of smart cutting but I haven't played around with it myself yet.
MKVMergeGUI is quite capable of splitting but it has the same keyframe limitation and of course doesn't give you any preview for selecting the cut/split points, but as I don't do much cutting myself I use MKVMergeGUI for it when I do, after opening the video in a media player to work out where it needs to be cut/split.
Any program capable of cutting without re-encoding should be pretty fast.... as fast as your hard drive can read and write.
SolveigMM Video Splitter 3 Release. AVC/264, MOV, MKV, MP4 on board
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 1st Feb 2012, 10:42 -
Gabest MP4 splitter vs. Haali Media Splitter
By jaduvil in forum Software PlayingReplies: 4Last Post: 16th Jun 2010, 11:57 -
editors for multi audio TS or mp4 video
By felix in forum EditingReplies: 1Last Post: 31st Aug 2009, 19:56 -
How do I replicate Camtasia 6 high quality MP4 in other video editors?
By raysolomon in forum Video ConversionReplies: 3Last Post: 3rd Mar 2009, 20:32 -
By raysolomon in forum Video ConversionReplies: 1Last Post: 3rd Mar 2009, 18:44
