when calling:
I get a log of:Code:"g:\avs2yuv.exe" "H:\Temp\tempPreviewAvisynthFile09_24_41_503.avs" - | "G:\mplayer.exe" -slave -demuxer y4m - -forcedsubsonly -nosub -noautosub -noidx -noaspect -cache 20480 -fps 25 -ao win32 -vo direct3d -lavdopts threads=1
messages.Command buffer of file descriptor 0 is full: dropping content.
When I remove the "-slave", everything works fine, but since I need the slave mode I wanted to know if someone knows how to fix this?
Cu Selur
Ps.: I plan to do this on Linux&MacOSX and not just on Windows, so directly opening the Avisynth script through mplayer won't work, also mplayer might be 64bit and Avisynth is always 32bit on my systems.
Results 1 to 1 of 1
AHCI mode Worth Installing to Replace IDE mode?
By wulf109 in forum ComputerReplies: 13Last Post: 24th Aug 2012, 12:42 -
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 07:52 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 00:48 -
Need slave function for capturing
By doggyjumper in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 11:06
