Hi i have done a function for hdr that works very good when i use it for my 8mm transfer heh it did take me many many hours to find the right method or that did work very good for me anyway here it is
clip a_stab=normal exposure or low exposure
clip b_stab=High exposure
and you need HDRAGC from http://strony.aster.pl/paviko/hdragc.htm
Here is some photos of my telecine diy but on does pictures i did not use this function for HDR it was a older function that was not so good http://www.flickr.com/photos/94271811@N03/Code:function hdr(clip a_stab,clip b_stab) { ab=overlay( b_stab,a_stab,x=0,y=0,mask=b_stab,opacity=0.5,greymask=true,mode="Multiply",pc_range=true) t=a_stab.coloryuv(autowhite=true).TurnLeft().HDRAGC(max_gain = 3.0,min_gain=0.5,coef_gain=2.0,coef_sat=2.00,MODE=1,shadows=true,protect=1,corrector=0.8).TurnRight() ab1=overlay(a_stab,b_stab,x=0,y=0,mask=a_stab,opacity=0.5,greymask=true,mode="hardlight",pc_range=true) l=overlay(ab,ab1,x=0,y=0,mask=ab,opacity=1.0,greymask=true,mode="blend",pc_range=true).coloryuv(autowhite=true) last=overlay(l,t,x=0,y=0,mask=ab,opacity=1.0,greymask=true,mode="blend",pc_range=true).TurnLeft().HDRAGC(max_gain = 1.5,min_gain=0.1,coef_gain=2.0,coef_sat=0.90,MODE=1,shadows=true,protect=1,corrector=0.8).TurnRight() return last }
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Looking at your pictures, it looks to me like you are oversharpening. Look at the white halo you have added along the white/black transition at the top of the frame.
Cheers,
David. -
yes hehe you are absolutely right in one of the avisynth pictures you can see little pixel grid or bayer pattern even
I did use videofreds script and did have unsharpmask at 125 if i remember right and that was to much
Last i did use the script i did have unsharpmask at 75 have to experiment more -
i have more info on the fuction here and a aling script to and some hdr examples
http://forum.filmshooting.com/viewtopic.php?f=1&t=24257 -
yes you are right
hmm the link i did post did work this morning but not anymore -
Here is a clip to see the hdr in action
https://vimeo.com/m/73398189
i did buy this super 8 from ebay
HDR Still Editing
By budwzr in forum EditingReplies: 47Last Post: 18th Jun 2017, 12:30 -
HDR Revisited
By budwzr in forum EditingReplies: 7Last Post: 26th Oct 2012, 16:02 -
Anybody do HDR video?
By budwzr in forum EditingReplies: 13Last Post: 10th Jul 2012, 00:02 -
hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Aug 2008, 16:28 -
Switch off AE. Sony HDR SR
By DavidEJM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 24th Jul 2008, 10:06
