  1. I'm a MEGA Super Moderator Baldrick's Avatar
    If you have problems importing your video files(like WMV, MP4, FLV, MKV, MPG, VOB, MTS, M2TS) in Adobe Premiere Pro, Final Cut Pro, iMovie, etc can you try reconvert it to a Prores mov file that should work to import.
    Software:
    TEncoder. FREE! (for Windows only)
    Guide
    Install TEncoder.
    Click on the + to load your video files, single files or entire folders.
    Under the Video Options tab set Video Codec: ProRes, Common sizes: Original, FPS: Same as source, Aspect ratio: Keep
    Under the Audio Options set Audio Codec: WAV.
    Set the output folder.
    Encode!
    Wait....
    Done! Now try import the mov file in Adobe Premiere Pro, Final Cut Pro, iMovie, etc.
    iMovie example:
Name:	Screen Shot 2013-05-19 at 12.43.34 PM.png
    Problems
    You might need Quicktime and Apple ProRes Quicktime Decoder, if you are using Adobe Premiere Pro for windows.
    Feb 2016
    Emilia Romagna - Italy
    Thanks for the useful hints of your post...
    I have used the guide and the software to convert some mts to mov for use within DaVinci Resolve 12.
    I have used VideoHelp forums a lot for my personal project and always saved me!!!
    Thanks again!
    Bye
    Paolo
