all i want is the command line mencoder, not some player/coder. when i type in mencoder in this box, it highlights and provides link, but takes me to mplayer which takes me to smplayer
i will try google.
edit: ahh, i give up.. can't find it. i thought it was probably packaged in mplayer, but the one i have is not. i guess they don't maintain it anymore. i have other things to do. tx anyway.
Results 1 to 11 of 11
it can be hard to locate and it is with mplayer
http://code.google.com/p/mplayer-for-windows/downloads/detail?name=mplayer-svn-36175.7z&can=2&q=--
i found one.. this time i entered mencoder.exe at google..
http://www.google.com/url?sa=t&rct=j&q=&source=web&cd=1&cad=rja&ved=0CDEQFjAA&url=http...45645796,d.dmQ -
if you had downloaded mplayer you had found mencoder in the the zip/7z.
http://sourceforge.net/projects/smplayer/files/MPlayer%20builds/03_2013/mplayer-svn-35...66.7z/download
Added the google code link also. I wont host it because they are releasing new builds every minute. -
that is not easy to know if you're not familiar with these tools. d/l'ed, again, thank you for helping.
then i must have old mplayers bc it was not in the pkg, all is sorted out now, ty.
I changed the download link to http://code.google.com/p/mplayer-for-windows/ and added a note that mencoder is included in mplayer.7z.
My builds on Google code are moving to http://mplayerwin.sourceforge.net/downloads.html since Google code will disable creating new downloads in January. If you can kindly update the link. 64-bit builds also added.
SMPlayer in ubuntu (Unity & Gnome)
By Hoser Rob in forum LinuxReplies: 1Last Post: 22nd Sep 2012, 07:52 -
SMPlayer not remembering to start maximized (different that full screen)
By natalia25 in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2012, 09:26 -
smplayer multiple chapter playing
By tao63 in forum Software PlayingReplies: 0Last Post: 21st Sep 2011, 09:35 -
smplayer slow down
By tao63 in forum Newbie / General discussionsReplies: 1Last Post: 15th Apr 2011, 08:56 -
SMPlayer with DivX h.264 decoder
By cex in forum Software PlayingReplies: 4Last Post: 15th Oct 2009, 22:01
