Hi
Bit of a minefield when it comes to converting AVI to MP4 and get a compliant version which will play in standalone bluray players ( Disk and/or USB pen )
I have tried a number od programs and the best so far is WINX free AVI to MP4 converter. However although I can get the video to play in my SONY BDS 185 Player, the screen is like the old 4.3 display. Cant get it t wide screen. Files `A`
If I play the files `A` through my media player, then everything is ok, but I want to put the files on a dvd and play on the bluray as a data disk.
I also have some other files `B` which play fine on both media player AND the bluray.....
I have used mediainfo to check the codecs etc and there are differences.
Is there a program to allow me to convert AVI to MP4 and allow me to enter the settings that are contained in the `B` files .
Cant think what else to do.
Thread: re AVI to MP4 conversion
Bought winx hd video converter deluxe.
I use the settings 1280X720 bitrate 1200 and audio 128 48000....
The only issue i have is it doesnt display full screen or 16.9 it has a 4.3 screen ( or so it looks like ) plays ok with my media player same tv ) but the sont bluray is being a pain.
Will try the program you suggested, unless you have any more ideas what might be wrong
Thanks -
Conversion from MKV to AVI/MP4 Artifacting
By SakuyaFM in forum Video ConversionReplies: 4Last Post: 14th Sep 2010, 20:41 -
MP4 VFR to AVI CBR conversion...
By Atakanbasturk in forum Video ConversionReplies: 0Last Post: 16th Jul 2010, 12:20 -
MP4 to avi without conversion?
By forcedv in forum Video ConversionReplies: 1Last Post: 14th May 2010, 19:02 -
Conversion avi - MP4
By condorsoaring in forum Video ConversionReplies: 5Last Post: 7th Oct 2009, 04:14 -
High quality AVI to MP4 conversion?
By conchord in forum Video ConversionReplies: 14Last Post: 27th Sep 2008, 10:22
