Hello. Is there any application that allows previewing in real time, encoding audio and video of a movie and instantly displaying it on the screen, instead of only letting the user encode a part of it and playing it after the conversion has been completed?
I'm dealing with x264 and AAC or MP3, but I'm more concerned about the video stream.
I tried at least in Avidemux activating the output button under the main menu bar, but it seems to show filters results only, the video stream is the source one, not the encoded one.
I barely remember a test with another program some months ago, with the same results. Maybe it was VirtualDub or something else.
Thank you.![]()
Results 1 to 11 of 11
Thread: Real-time preview
Falco2000, video newbie.
Let's everyone help each other. -
Google with the string: "preview while encoding". Maybe you get some tips.
AVS Video Converter use preview while encoding. -
Yes, a lot of serial snapshots. Because it doesn't show all the frames.
I think no program will, especially not with "heavy" parameters.
If you want to see what it's gonna be smoothly, I think it has to be like HandBrake does it. To encode a small part of the video and watch it. i.e. 30 sec. -
Corel Video Studio does
VLC can view the .h264 file while the encoder is still running.
Yes, just specify an output filename with .MKV or .MP4 as the extension (this may vary depending on the build you use). But I haven't found a player that will view MP4 output while the encoder is still running. -
Ok, thank you for all of your answers.
Real time for rendering a movie
By Sweetamber in forum ComputerReplies: 6Last Post: 25th Oct 2012, 14:07 -
Real time ac3+ transcoder?
By andyhuk in forum AudioReplies: 1Last Post: 13th Jul 2011, 22:14 -
Real Time Chroma Preview for PC
By Travis Weather in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2010, 20:23 -
Real time test of media - whether I like it or not
By arcorob in forum MediaReplies: 12Last Post: 18th Feb 2010, 20:55 -
Real time recording
By slaak in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 22:27
