    I accidentally deleted 2 avi files from my sd card. I have used Card recovery software to recover the files and it's returned 19 files from my card. When I try to play them in VLC player, WMP, Zoom, Gom player they either return an unrecognised file error or msg that the required codec is missing. I have installed numerous codecs and still get the same error. I have put the recovered folder in mediainfo and the results are below. Can someone advise what I can do next please? Im very new to this and not very technical. Thanks.
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0001.AVI
    Format : AVI
    File size : 32.0 KiB
    Duration : 3mn 37s
    Overall bit rate : 1 207 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 37s
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 30.000 fps
    Color space : YUV
    Compression mode : Lossy
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 3mn 37s
    Bit rate mode : Constant
    Bit rate : 176.4 Kbps
    Channel(s) : 1 channel
    Sampling rate : 11.025 KHz
    Bit depth : 16 bits
    Stream size : 4.57 MiB
    Alignment : Aligned on interleaves
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0002.AVI
    Format : AVI
    File size : 193 MiB
    Duration : 3mn 37s
    Overall bit rate : 7 454 Kbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 37s
    Bit rate : 6 974 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bits/(Pixel*Frame) : 0.757
    Stream size : 181 MiB (94%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 37s
    Bit depth : 16 bits
    Stream size : 4.57 MiB (2%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0003.AVI
    Format : AVI
    Duration : 4mn 9s
    Overall bit rate : 1 053 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 4mn 9s
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 4mn 9s
    Bit depth : 16 bits
    Stream size : 5.24 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0004.AVI
    Format : AVI
    File size : 219 MiB
    Duration : 4mn 9s
    Overall bit rate : 7 372 Kbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 4mn 9s
    Bit rate : 6 895 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bits/(Pixel*Frame) : 0.748
    Stream size : 205 MiB (94%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 4mn 9s
    Bit depth : 16 bits
    Stream size : 5.24 MiB (2%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0005.AVI
    Format : AVI
    Duration : 3mn 26s
    Overall bit rate : 1 271 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 26s
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 26s
    Bit depth : 16 bits
    Stream size : 4.34 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0006.AVI
    Format : AVI
    File size : 191 MiB
    Duration : 3mn 26s
    Overall bit rate : 7 755 Kbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 26s
    Bit rate : 7 263 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bits/(Pixel*Frame) : 0.788
    Stream size : 178 MiB (94%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 26s
    Bit depth : 16 bits
    Stream size : 4.34 MiB (2%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0007.AVI
    Format : AVI
    Duration : 3mn 29s
    Overall bit rate : 1 254 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 29s
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 29s
    Bit depth : 16 bits
    Stream size : 4.40 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0008.AVI
    Format : AVI
    File size : 282 MiB
    Duration : 3mn 29s
    Overall bit rate : 11.3 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 29s
    Bit rate : 10.7 Mbps
    Width : 640 pixels
    Height : 480 pixels
    Color space : YUV
    Bits/(Pixel*Frame) : 1.159
    Stream size : 266 MiB (94%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 29s
    Bit depth : 16 bits
    Stream size : 4.40 MiB (2%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0009.AVI
    Format : AVI
    Duration : 2mn 14s
    Overall bit rate : 1 946 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 2mn 14s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 15.000 fps
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 2mn 14s
    Bit depth : 16 bits
    Stream size : 2.83 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0010.AVI
    Format : AVI
    File size : 230 MiB
    Duration : 2mn 14s
    Overall bit rate : 14.3 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 2mn 14s
    Bit rate : 13.6 Mbps
    Color space : YUV
    Bits/(Pixel*Frame) : 0.436
    Stream size : 218 MiB (95%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 2mn 14s
    Bit depth : 16 bits
    Stream size : 2.83 MiB (1%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0011.AVI
    Format : AVI
    Duration : 3mn 19s
    Overall bit rate : 1 313 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 19s
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 19s
    Bit depth : 16 bits
    Stream size : 4.20 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0012.AVI
    Format : AVI
    File size : 380 MiB
    Duration : 3mn 19s
    Overall bit rate : 16.0 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 19s
    Bit rate : 15.1 Mbps
    Color space : YUV
    Bits/(Pixel*Frame) : 0.487
    Stream size : 360 MiB (95%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 19s
    Bit depth : 16 bits
    Stream size : 4.20 MiB (1%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0013.AVI
    Format : AVI
    Duration : 3mn 11s
    Overall bit rate : 1 371 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 11s
    Frame rate : 14.989 fps
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 11s
    Bit depth : 16 bits
    Stream size : 4.02 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0014.AVI
    Format : AVI
    File size : 430 MiB
    Duration : 3mn 11s
    Overall bit rate : 18.9 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 3mn 11s
    Bit rate : 17.9 Mbps
    Color space : YUV
    Bits/(Pixel*Frame) : 0.577
    Stream size : 409 MiB (95%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 3mn 11s
    Bit depth : 16 bits
    Stream size : 4.02 MiB (1%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0015.AVI
    Format : AVI
    Duration : 4mn 14s
    Overall bit rate : 1 030 bps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 4mn 14s
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 4mn 14s
    Bit depth : 16 bits
    Stream size : 5.35 MiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0016.AVI
    Format : AVI
    File size : 357 MiB
    Duration : 4mn 14s
    Overall bit rate : 11.8 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 4mn 14s
    Bit rate : 11.1 Mbps
    Color space : YUV
    Bits/(Pixel*Frame) : 0.358
    Stream size : 338 MiB (94%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 4mn 14s
    Bit depth : 16 bits
    Stream size : 5.35 MiB (1%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0017.AVI
    Format : AVI
    Duration : 13s 3ms
    Overall bit rate : 20.2 Kbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 13s 3ms
    Frame rate : 15.073 fps
    Color space : YUV
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 13s 3ms
    Bit depth : 16 bits
    Stream size : 280 KiB
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\File0018.AVI
    Format : AVI
    File size : 12.6 GiB
    Duration : 13s 3ms
    Overall bit rate : 8 292 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 13s 3ms
    Bit rate : 7 963 Mbps
    Color space : YUV
    Bits/(Pixel*Frame) : 254.788
    Stream size : 12.1 GiB (96%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 13s 3ms
    Bit depth : 16 bits
    Stream size : 280 KiB (0%)
    General
    Complete name : C:\Users\Lynn\Documents\CardRecovery\2013-03-18\TmpFiles\AboutThisFolder.txt
    File size : 1.07 KiB
    Have you tried open them in any video editor or converter? Like virtualdub, avidemux and see if they can read them? If so try save as a new avi.
    Or try convert them with for example video to video converter, xmedia recode.
    But I guess they all will fail or crash...I haven't seen any good avi mjpeg repairer.
    Hi bobyyaris,
    As explained by Baldrick a good avi mjpeg repairer is yet to come. I guess that your best chances are to try suggested video editors/converters and see if they can be "ironed" into a new avi file. You could also try with VLC as it is able to fix the index of the avi structure making playable some apparently corrupted files.
    An alternative approach would be to try again to recover the files from the card using the instructions related in the post Recover Deleted Videos on an SD Card and then repair them. Best of luck!
    --Fire
