windows xp 32 bit, mpc-hc 1.6.6.6899 (7062122) was using ffdshow decoder, directvobsub, haali media splitter.
after I watch a video with mpc-hc and close it using the X on the upper right corner, the mpc-hc.exe doesn't disappear from task manager in the list of processes. as I watch and close more and more videos, I get a long list of mpc-hc.exe piling up on the list
should I force end the processes on the task manager? will this actually free up my memories? is this good or bad to do? how can I prevent this from happening in the 1st place so when I close mpc-hc it actually free up the memories?
I remember I had to delete all MPC processes in task manager. No harm was done.
Those processes started to accumulate only after some error, not proper exiting. So for some kind of video it really means perhaps using stop button first and after mpc realy stops then X to exit window. If I left one process running, not knowingly - mpc.exe was still listed in task manager and I started new process it behaved that way, it started to accumulate processes there. I had to end all of those processes in there. -
Does the MPC-HC exe remain in task manager every single time? It shouldn't, but it does sometimes happen. Ending the MPC-HC processes in task manager won't do any harm.
It might pay to open a video using nothing but MPC-HC's internal filters to see if the problem persists. If it doesn't then you could try adding ffdshow and haali etc to the mix one at a time to see if one of them are causing it, although if they are, I'm not sure how you'd go about fixing it.
Media Player Classic Home cinema dubdelay
By web_maven in forum Software PlayingReplies: 2Last Post: 17th Mar 2012, 06:01 -
Media Player Classic - Home Cinema Settings Help
By ACiDxCHRiST in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2011, 23:29 -
Questions about Media Player Classic Home Cinema
By Seeker47 in forum Software PlayingReplies: 10Last Post: 31st Mar 2009, 11:50 -
Question about Media Player Classic Home Cinema
By mysts in forum ComputerReplies: 4Last Post: 18th Mar 2009, 07:44 -
Media player classic Home cinema w/ ac3filter
By clamchowder01 in forum Software PlayingReplies: 1Last Post: 16th Oct 2008, 03:49
