Short MPEG2 sample. Also I've used McTemporalDenoise on Medium and QGTMC on Super Fast but I can still see lots of noise. How can I remove that noise?
Looks as if someone already processed this super-low-bitrate original with a temporal filter set too high. Otherwise, there's not much "noise" in the usual sense, except that low bitrates have destroyed detail, screwed up edges, created mosquito noise all over the place, and cause much distortion -- especially every time something moves. The MPG bitrate is around 4000 (far too low for action video), but there appears to have been an earlier step whose bitrate was even worse. Might have been XVid or something ? ?
Not much you can do with the ghosting. The major work would be cleaning up edges and contours. The black levels are OK, but somebody really likes red and hates highlights -- thankfully, at least they didn't blow away most of the brights.Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
I didn't comment earlier because the video is beyond hope.
How to fix speedup with AviSynth?
By VideoFanatic in forum RestorationReplies: 45Last Post: 5th Feb 2013, 17:28 -
Image Tracing Advice Needed
By budwzr in forum EditingReplies: 12Last Post: 29th Nov 2012, 23:08 -
Old video card ghosting - any way to fix it?
By Ai Haibara in forum ComputerReplies: 7Last Post: 15th Feb 2011, 14:49 -
x264 problem: Movie bad + fix = Digital ghosting and out of sync picture
By Kim Jespersen in forum DVD RippingReplies: 7Last Post: 6th Nov 2009, 17:35 -
How do you fix ghosting?
By zanos in forum Video ConversionReplies: 4Last Post: 27th Apr 2008, 00:21
