This the camera I have:
http://www.wired.com/gadgets/digitalcameras/magazine/test2007/vc_panasonic_hdc_sd1
And this is the microphone I have:
http://www.bhphotovideo.com/c/product/744768-REG/Rode_VIDEOMIC_PRO_VideoMic_Pro_Compact_Shotgun.html
The mic plugs into the jack of the camera but because there is not a mount on top of the camera I don't know how Im going to use the microphone without having to hold it. Is there a part I can buy to stick on top of the camera that will hold this light weight mic? Or should I try to find a mic stand that would be able to hold this mic so I can set it next to the camera? Not sure what to do, need a clever idea.
Something like this, though the stabilizing claims are pretty much nonsense.
http://www.bhphotovideo.com/c/product/747112-REG/Vello_VB_1000_ActionPan_Professional_...abilizing.html -
Okay great Ill look for something like this, but can this connect to a tripod? I need something like this that can connect to a tripod.. SOL? Thanks for the replies
Camera Mic Problems
By FryeStudios in forum AudioReplies: 3Last Post: 27th Apr 2012, 09:40 -
Audio/Mic problem during filming, need a solution..
By sdsumike619 in forum AudioReplies: 16Last Post: 31st Jan 2012, 18:17 -
Camera - IEEE 1394, Compsite and mic in???
By djlerman in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 9th Jan 2012, 23:58 -
Need help buying a second hand camera with external mic
By OM2 in forum Camcorders (DV/HDV/AVCHD)Replies: 15Last Post: 18th May 2009, 20:10 -
Hi-revive cleaning solution for my digital video camera.
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2009, 06:41
