Some time ago I installed Mediacoder 0.8.15.5290 because I had heard that it was a very good encoder and produced high quality video. Well, I've tried several times to convert .flv or .mp4 files with it and every time I get some kind of error. I've yet to convert a single file with it. The error that I see most frequently is error 015 (a muxer error has occurred). The strange thing is that when this happens I turn to Xmedia Recode or AVS2DVD and both of those programs will convert the same file with no difficulty. What's with Mediacoder? Has anyone here used it successfully?
Thread: Problems With Mediacoder
ganymede
Maybe try latest mediacoder? 0.8.19?
BUt I don't like the gui. And you should be able to get same quality with other converters like xmedia recode, vidcoder, etc as most are based on same encoders like ffmpeg, libav, x264 encoder. -
MediaCoder offers a lot of flexibillity. However, it rely on you to make sensibel choices and don't check wether those are right. Apparently you are trying to mix incompatible codecs/container.
And I use MediaCoder succesfully all the time. -
OK guys, thanks for your comments. By default I've been using either Xmedia Recode or AVS2DVD by virtue of the problem I've been having with Mediacoder and I may have to stay with those, but I will take a look at Mediacoder 0.8.19. Maybe I'll have better luck with that. As to your comments videobruger, I am probably doing something wrong but at this point I have no idea what it is but would like to know. If I posted a summary of the file properties and of the settings I chose in the wizard, would you be willing to take a look at them? Perhaps there may be something obvious that is causing the problems that I am having.
ganymede -
@ganymede
Yes I can take a look at it.
Use MediaInfo for your source. Then File -> Export -> Text and create a .txt file
In MediaCoder use File -> Save as Preset and create a .xml file
Upload those two files with Upload files/Manage attachments and I'll see what I can do. -
Hi videobruger,
Thanks for your offer to help me solve the problem I was having with Mediascoder. However, shortly after I posted my last message the problem was solved. The only thing that I did differently was to move Mediacoder to a different hard drive. As I was trying to figure out what could possibly be going wrong, I noticed that the hard drive had less than 1.5 GB of free space. It occurred to me that while the files I was trying to process were relatively small, perhaps the program needed more disc space for the temporary files that are created during such an operation. So I re-installed Mediacoder to another drive that had more than 60 GB of free space. I have had no difficulty processing any files after that change. I'm not 100% certain that my assumptions about the disc space issue were correct but at least Mediacoder is working fine now.
ganymede -
@ganymede
I think your assumptions about disc space is correct. I've seen this error before due to lack of space in the final muxing. In the latest version 0.8.19 there is a test for free space (not all that familiar with it - I think it excaggerette the space needed when making "clips")
New Mediacoder with CUDA problems.
By Stears555 in forum Video ConversionReplies: 26Last Post: 11th Jan 2013, 22:44 -
AVCHD conversion with MediaCoder
By Liss0 in forum Video ConversionReplies: 1Last Post: 20th Mar 2011, 02:35 -
Mediacoder ERROR !
By vickynash in forum Newbie / General discussionsReplies: 5Last Post: 1st Jul 2010, 08:26 -
Mediacoder question
By Serville in forum Video ConversionReplies: 2Last Post: 21st Jan 2010, 03:11 -
Is MediaCoder 0.7.0.4396 Safe?
By gonwk in forum Newbie / General discussionsReplies: 14Last Post: 23rd May 2009, 18:08
