Results 1 to 9 of 9
  1. Hi everyone.
    I have this MPEG-2 video which has distorted aspect ratio when played.
    I tried searching around but this problem doesn't seem that common. All I got was people having problems with 4:3 and 16:9 and etc.
    The distorted aspect ratio... I don't even know what it is.
    The first image below shows the aspect ratio when played.
    The second image is what it should be. It was achieved by manually selecting the 4:3 aspect ratio in VLC media player.
    Attached Thumbnails Click image for larger version
  2. What's the current resolution and DAR? If you don't know, open it in MediaInfo and find out. If playing it as 4:3 fixes it, you can demux it, set a DAR of 4:3 in ReStream, then then remux it.
  3. According to MediaInfo, the resolution is 720 x 576 and the aspect ratio is 21.333.
  4. OK, here's one way to fix it (I think):
    1. Demux it. Open it in DGIndex and File->Save Project and Demux Video. That will give you an M2V, the AC3 (or whatever audio it is) and a D2V project file you can delete.
    2. Open the M2V in ReStream and in the top center change the aspect to 4:3. Save out a new M2V.
    3. Remux with ImagoMPEG-Muxer.
  5. Originally Posted by manono View Post
    I successfully demuxed it.
    However when I opened the M2V in ReStream the aspect ratio was already specified as 4:3, even though it was still distorted.
    I clicked "Write!", the result was still distorted.
    Look for a Sequence Display Extension. Set it to 720.
  7. Originally Posted by MPGAP View Post
    OK then, sorry. Try jagabo's suggestion.
  8. Originally Posted by jagabo View Post
    I followed your suggestion. But there seem to be a little problem.
    Demuxed video does not play in VLC or Windows Media Player.
    After I muxed the video and audio, it plays in WMP, but still VLC doesn't work.
    Your other suggestions were still useful. Thanks though!
  9. I managed to solve it.
    1. Demux it with DGIndex.
    2. Open M2V in ReStream and remove the Sequence Display Extension.
    You guys are the best. Thank you!
