When trying to rip subtitles from a DVD with SubRip, I am having problem when there is a % in the text (percent sign). SubRip detects it as three different characters, and I can not figure out how to teach it that this is only one character?
Have convert the first "character" to "%" then ignore the next two. Or some other combination, whichever is least likely to result in incorrect conversions later on.
You can use the ">>" button (extend selection right) to select the entire "%" character.
Another option would be to use OCR via Tesseract in Subtitle Edit. -
Detecting errors
By leftspeaker2000 in forum Video ConversionReplies: 2Last Post: 1st Nov 2012, 10:59 -
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum CapturingReplies: 1Last Post: 16th Nov 2009, 00:11 -
VideoReDo Not Detecting Audio
By MegaTonTerror in forum Video ConversionReplies: 3Last Post: 11th Nov 2009, 14:39 -
SubRip Issue.. Unrecognisable Characters!
By Mark-2009 in forum SubtitleReplies: 6Last Post: 16th Sep 2009, 15:12
