    Hi
    Have used Potplayer on my Acer Revo for a couple of years for HD MKV playback without issue.
    However I am now getting occasional picture tearing, mostly in fast moving scenes or when the camera pans.
    Tried reinstalling Potplayer with latest version and the issue persists.
    CPU usage fine at ~ 30% and DXVA enabled. I use a wireless dongle on the Revo as my set up is controlled via iPhone.
    Any ideas what's up?
    Russ
    Did you try the "Fix Broken V-Sync..." Option? Other video renderers?
    Tearing occurs when the frame buffer is switched while the graphics card is in the middle of displaying a frame (the top part of the picture you see is one frame, the bottom another). Synchronizing the frame buffer switch to the vertical sync prevents this.
    Hi Jag
    Thanks for replying, I will give that a try!
    Cheers again
    Russ
    Tried it and the tearing remains
