I have a lot of .mkv files I made with MeGUI. Some of which are music videos (no chapters/subtitles) and others are TV episodes (with chapters/subtitles).
I would like to know how to burn the .mkv TV episodes to DVD5 and still have the chapters/subtitles work like they do in a regular DVD.
I would rather not have to transcode the videos to another format, if possible.
If transcoding is required, what is the process required to get these files to play on any standard Blu-ray player (I have a Samsung HT-C5500).
I would just like to burn these videos to DVD's as backup hard copies instead of only storing them on HDD.
I did some searching, but searching for "burning mkv files to DVD" seems to bring up a lot of conversion tools to DVD, which I don't want to do.
Any suggestions, comments or questions?
Results 1 to 9 of 9
Why do you use white color in the text?Copied from another black forum?
If you want standard dvd-video format must you reconvert. -
OK, that is clearly not the way I wrote it.
No, I didn't copy it from another forum, this is the only place I posted.
I don't want to convert it to DVD format (i.e. vob's), just burning the mkv backups preserving the chapters/subtitles. -
Can't you just use windows copy files to DVD as a data disk? Guess XP has some problems burning data to a DVD. You can read more here: http://www.informit.com/articles/article.aspx?p=101758
use imgburn in build mode. drag the mkv file into the window and burn. as long as it is less than 4.3GB and fits on a DVDr it should just burn the file as is, it will still be the original mkv on the disc.
Sorry, I'm using Windows 7 64bit, not XP.
@ wulf109
What is considered a "normal" mkv format?
I just used Imgburn with UDF 2.50 to create iso file, then burned to DVD+RW for testing.
Audio/video plays as expected, but no chapters, subtitles or even fast-forward or rewind.
I also tested streaming mkv from PC with the subtitles extracted and renamed to match video, now subtitles work.
Apparently Samsung has issues with embeded subtitles in mkv files.
On the other hand, .avi files burned to DVD has the following enabled:
- fast-forward 3 speeds
- rewind - 3 speeds
- slow-motion - also 3 speeds
I need to do some checking on the subtitles or support for avi subtitles.
I wanted to use the mkv format due to its use of chapters, subtitles, audio tracks, etc., but if a stand-alone player won't play them, then what's the point in using that format? Ideas? -
there is no standard for mkv playing on a blu-ray player. every player is different, the only standard is a blu-ray disc. you could try converting to avchd disc which is closer to blu-ray on a dvdr. try multiavchd or bdtoavchd
MKV is not a commercial format. While the specs are available, since it's not a commercial format and there's no certification board for it, devices that support it are free to implement it in any way this wish, which may mean partial support. Most devices that support MKV play the subtitles fine, provided that the subs are in a subtitle format the device supports. Getting chapters to work is a whole other story. To be blunt, if you are going to go gung ho into MKV then you have to accept that at least at present chapter support is very iffy and you should expect it to not work more than it works.
My limited experience is that most standalone devices that support MKV don't fully implement it. I've got an MKV file I made where I had a video only with a foreign language soundtrack. The original source video is Xvid. I put the Xvid video and an English soundtrack that I had to delay some miliseconds to get it to sync into an MKV container and none of my players that support MKV would touch it, even though the audio was good old AC3 and all of them could play the original AVI file that contained the video with the foreign language soundtrack. So this just shows you that there really are no guarantees right now about MKV if you use anything but a PC for playback.
How do i burn a mkv to dvd5?
By peanut28 in forum Video ConversionReplies: 10Last Post: 28th Feb 2013, 13:39 -
MKV (w/multi audio, subtitles, chapters) to DVD
By Quamatek in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2013, 23:38 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 19:12 -
Burn MKV Files With Choice Of Subtitles?
By Valentin in forum Authoring (DVD)Replies: 1Last Post: 4th Aug 2010, 20:21 -
converting PAL DVD to NTSC while preserving chapters
By andreyvul in forum LinuxReplies: 10Last Post: 2nd Sep 2009, 03:04
