Sorry for my bad English.
I have 3000+ KARAOKE video with 2 audio stream(some of it only 1 audio stream).
Decide to convert all video stream to h264 and copy audio stream (without encore audio stream).
So far tried following software and GUI, but most of it can't auto copy both audio streams.
XviD4PSP5;
AviSynth 2.5;
Avidemux 2.6;
XMedia Recode;
Smallx264; (only copy 1 audio streams)
Handbrake; (need manually setup both audio streams)
TX264; (have error convert failed)
I'm a newbie, want to try WinFF or other GUI, but I don't know the command line to batch convert the KARAOKE library.
Hopefully someone can help me here...
You must probably use ffmpeg with a custom batch file. It will be a lot of work if you have no idea how to use command line tools...
Some encoding examples https://www.virag.si/2012/01/web-vid...th-ffmpeg-0-9/ and use the map command to keep both audio tracks http://ffmpeg.org/trac/ffmpeg/wiki/H...0-map%20option -
Thanks. It's very helpful. Combine with WinFF, seem likes it's work perfectly.
Attachment image is my WinFF preset.
Also one more problem, WinFF not support foreign character name.
Any software suggest for me to batch rename filename and then after encode undo the rename? -
Nope. It will just take longer time to encode.
I use this program to batch rename files all the time. It's saved me many hours on several projects.
http://4sysops.com/archives/free-1-4...-renamer-tool/
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 09:46 -
Can't find H264 in TMPGEnc?
By Mizzle in forum Video ConversionReplies: 0Last Post: 30th Dec 2009, 17:24 -
convert TrueHD to flac w/ eac3to GUI
By runLoganrun in forum AudioReplies: 3Last Post: 10th Dec 2008, 10:50 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 15:53 -
GUI to convert Matroska (*.mkv) To AVI
By qwerty9876543 in forum LinuxReplies: 4Last Post: 17th Mar 2008, 21:38
