I play movies on my LCD TV using an external hard drive (portable, usb powered) via USB. I also use my external desktop drive which uses a power source. Playback is about the same between the two. I would rather use a portable drive... but would a bigger drive using a power source be better in some way? Just wondering![]()
There won't be any change/difference in the video quality (as long as you're playing the same video file) whether you use a larger externally-powered drive or a portable USB-powered drive.
The only problem that I can see happening is if the USB port on the TV can't supply the necessary current to power the portable drive... but since it seems to be working, then apparently it can supply the needed current to power up the portable drive….You can't fool me, I'm a moron! -
That was my main concern. Making sure the playback was the same between the 2
I have been testing out the portable drive and it's a lot quieter (WD)
DTS Audio not recognized when I play movies from my extern HDD through PS3!
By Spdngblt56 in forum AudioReplies: 1Last Post: 8th May 2010, 17:51 -
recover *.mts files from external HDD ..tried restoring hdd software
By ravistudios in forum RestorationReplies: 0Last Post: 18th Mar 2010, 12:24 -
USB - What will it play on external HDD?
By THRobinson in forum DVD & Blu-ray PlayersReplies: 9Last Post: 30th Aug 2009, 09:49 -
Some MKVs Will Not Play from FW800 External HDD in Mac, Works in Windows
By encodedprocess83 in forum MacReplies: 1Last Post: 11th Dec 2008, 08:26 -
MKVs Won't Play from External HDD
By encodedprocess83 in forum Software PlayingReplies: 4Last Post: 10th Dec 2008, 01:02
