I still have an Xbox HD-DVD drive and a movie I can't replace, so I'm wanting to copy it to BD-R. Black Christmas (remake), specifically. What's the easiest way to do this? Does AnyDVD even support HD-DVD anymore? If I can rip it with that, where do I go from there?
Yes, AnyDVD HD still supports HD-DVD. Rip the entire thing to the hard drive as files.
Then use ClownBD to open the HD-DVD structure, and then output as Blu ray. You'll lose the menu and extras.
ClownBD is a gui for Eac3to and tsMuxeR, so you could probably use them instead, but ClownBD is an easy to use interface.
simplest DVD authoring freeware aside from GUI-forDVDAuthor and DVDAuthorGu
By texas1 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2012, 03:48 -
Simplest DVD authoring program?
By paristideu in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2011, 11:08 -
DVD - Mix Audio from two captures? What is the simplest solution?
By ChasePlace in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2010, 11:26 -
Simplest program to convert AVCHD to DVD
By Wam7 in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 25th Mar 2010, 12:29 -
simplest way to do this? DVD to MKV and split title tracks.
By ian_g in forum DVD RippingReplies: 4Last Post: 30th May 2009, 05:30
