Hi all. I have been playing some .mts files from a Canon Legria HFG10 that report as 1920x1080 and I have a computer screen the same size. Using VLC Media Player 2.0.5 Twoflower. In the menu Video -> Zoom -> 1:1 I would have expected it to fill the screen entirely seeing the file and screen resolution match. It only fills the screen about 95%. If I push the full-screen button it works fine.
What I want to know is, is 1:1 by the menu actually running 1:1 and the file is not actually 1920x1080, or is full screen really 1:1 and the menu 1:1 not quite so?
The 1:1 option probably only works when the video resolution is lower than the monitor resolution. Once they're the same (or close to), in order to account for the navigation/menu bars, VLC probably needs to resize the video down a little otherwise it'd have to stretch it in order for the video to fill the VLC window.
So along the lines of what jagabo said, if the menu and navigation bars are taking up 5% to 10% of the screen, then the video needs to be resized down by 5% to 10% so the height fills what's left of the VLC window, which means you end up with black bars down the sides.
The alternative is to disable the "always fit window" option under the view menu, and the sides of the video will then fill the entire width of the VLC window (I think, I don't use VLC much myself), but at the same time I think you'll lose some of the top and bottom of the video (effectively under the menu and navigation bars) until you change to full screen mode. -
Cool. thanks, guys. That does sound pretty reasonable that it would force the window borders if it was not in full screen mode. Now I can sleep.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
vlc 1.05 is very unstable and choppy in full screen
By octeuron in forum Newbie / General discussionsReplies: 13Last Post: 25th Apr 2010, 18:18 -
Video Quality for full screen on Media Player Classic?
By mimioreo in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 18:33 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23
