I recently bought a Hauppauge WinTV-HVR 1850 TV Tuner card. It works great, but I recently noticed I am capturing HD video at 60 fps. I am pretty sure most TV in America is shot at 24 fps. I tried DGIndex, assuming the 60 fps video might be encoded similarly to how a 24 fps DVD is written to the DVD as a 30 fps stream. But I couldn't get it to do what I wanted. Is there any way to convert back to the original 24 fps with simply down sampling? Is there something I am missing here?
Thread: Capturing at 60 fps, want 24 fps
Over the air broadcast in the USA is either 1280x720 59.94 fps progressive, or 1920x1080 29.97 fps interlaced (59.94 fields per second). That is what your capture card will capture because all it does it save the already compressed digital transport stream to a file.
Film sources will have duplicate frames or fields to match those specs. It's possible to restore the original 23.976 fps film frames but you will have to decimate or inverse telecine, respectively. Either will require a reencode which will lose quality.
Any decent way to convert higher fps movies to a lower 29.97 fps ? (or othe
By Jonz in forum Video ConversionReplies: 1Last Post: 5th Nov 2012, 02:01 -
Sync - Resample audio from video source of 29 FPS to 25 FPS
By Chastepe in forum AudioReplies: 6Last Post: 17th Oct 2012, 10:35 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
