    Hello all, I've just started dabbling in Motion 5 and am having a problem with one of my graphics. As the graphic becomes larger it looks as if it is wavy along the edges. The original file is quite large, could this be the problem? The original graphic is a jpeg. Here is a link to youtube to show what I mean since I can't really describe it. Any help as to what the problem is and how to fix it would be great!
    Thanks!
    http://www.youtube.com/watch?v=_plgSJYsV48
    I don't use motion, but try setting everything progressive instead of interlaced; both the project settings and the export settings
    You can see combing in your circle graphics (during the credits), in the tv screen (you wouldn't see combing on a CRT TV, only when viewed on a progressive flat panel), and around the edges
    Great! That did the trick!
    Thanks so much!
