Hey everyone!
First let me say I am completely ignorant with computer hardware. I don't know much beyond the basics.
I have a computer setup (specs below) for recording xbox. It uses a Black Magic Intensity Pro.
When I try to record in Motion JPEG I get a lot of dropped frames. When I record uncompressed it usually records perfectly, sometimes it drops a chunk of frames. When recording in Motion JPEG the faster / more action on the screen the worse it drops frames.
Is my computer simply just not powerful enough? Maybe I need a better graphics card or power supply?
Thanks in advance. Love the forum!
HP xw9300
WIN XP PRO 64
AMD Opteron Processor 252 (2 CPUs), ~2.6ghz
10240MB RAM
NVIDIA Quadro FX 3400/4400 256MB - Chip Type Quadro 3400
Results 1 to 10 of 10
Let me guess you're capturing (storing the videos) on the system disk and now are wondering what's going on with these dropped frames.
I have 4 Hard drives on a raid 0 array. Sorry should have posted this info in the OP. This computer is only used for capturing video.
Disk Write Speed: 296.7 MB/s
Disk Read Speed: 303.3 MB/s -
What's your framerate and raster size? Gameplay can be huge.
I am capturing in 720p 59.64. 1280x720. I hope that's what you're looking for. Sorry I'm not sure what raster size is. A ten min COD capture is usually around 55gb and it captures in great quality (uncompressed). It's not often it drops frames capturing uncompressed.
Any ideas? Do you think the elgato game capture may work better?
Ahhh ok, do you think the elgato would record ok on this system?
Probably. Since it uses a hardware h.264 encoder, all the CPU is doing is take data from the USB port and writing it to a file. Your graphics card will be doing the h.264 decoding for display. But, of course, check with the manufacturer.
Thanks for the help jagabo =0) I think I'll keep the BMI for raw capture and buy the Elgato for normal capturing.
Build me a computer for editing on Vegas Pro 11!
By tykempster in forum Newbie / General discussionsReplies: 9Last Post: 4th Oct 2012, 11:37 -
Will the Black Magic Intensity Pro work with my computer?
By GranolaThins in forum CapturingReplies: 2Last Post: 14th Jan 2012, 23:35 -
Can my setup run the Blackmagic Intensity Pro?
By Alienwarez in forum CapturingReplies: 19Last Post: 12th Jul 2011, 11:48 -
HD PVR vs BMI Pro - possibly quick question
By 80r in forum CapturingReplies: 2Last Post: 25th Mar 2010, 08:13 -
premiere pro+mainconcept hd: best hardware setup (hdraid, cpu, ram)?
By razzta2001 in forum EditingReplies: 9Last Post: 8th Oct 2008, 07:54
