In Pavtube video converter I use a "Directly Copy" format to convert/decode a Tivo video, just like it says there:
Everything goes quick & fine but the output video (502mb, 17 mins) differs from original Tivo video (840mb, 30 mins) don't know why. I tried converting that Tivo in usual way & all goes fine but then I lose the subtitles/CC which were in Tivo & are important to me. I can't extract them via CCExtractor or t2sami, so only hoping to do so via Pavtube."If you select Directly Copy, the converter will remove the protection by TiVo and restore the files to MPEG file (*.mpg) without any quality loss. As en-decoding progress is left out, the conversion speed will be much faster than the later. The converter will generate files right what they used to be before they were made into TiVo files (an inverse progress of encryption)."
Also, Videoredo crashes every time I try to add a Tivo in it.
I'm also curious, is there any other converters for Tivos that do that "Directly Copy" loseless function?
Results 1 to 1 of 1
Thread: Pavtube's "Directly Copy" issue
*sigh* Another issue - "force mono" missing in AutoGK.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 15th Apr 2013, 19:32 -
ImgBurn "options" problem/directly cloning DL DVD to a blank disc
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2012, 20:40 -
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 21:09 -
Gray "!" iTunes 8 annoying song location issue...
By Nintendo Fan in forum ComputerReplies: 12Last Post: 14th Jun 2009, 10:38 -
Can I bypass "copy blocker" to copy from VHS to DVD
By jgloeckner in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2008, 23:40
