On playback, I cannot get the jump keys ie left and right together with ctrl and shift to make the video jump forward or back.
Any ideas about what I am doing wrong please.
The other playback control keys such as z,x and c all work ok.
Thread: PotPlayer Jump Keys
Some ideas:
Ensure default keys are enabled - you can usually tell though as [F5] won't work, in which case:
- Right click in main window, Options, Ignore default shortcut keys (untick*)
Clear any custom keyboard shortcuts: [F5], General, Shortcuts.
Check default Time jump settings: [F5], Playback, Time Jump. (should be 5, 30, 60, 300 sec).
If all this fails, uninstall PotPlayer, clear the Daum registry keys (HKCU\Software\Daum\) with regedit.
Reinstall a different stable release of PotPlayer (although they are all technically Beta).
Try storing the settings to a ini file instead: [F5], General, Store settings to .ini file.
If using the ini file you can clear the Daum registry keys, use Export to save them first (just in case).
Keep a backup of the ini file in case of corruption.
PotPlayer "Jump to Middle" does not work anymore
By Johnny B in forum Software PlayingReplies: 11Last Post: 6th Feb 2013, 14:27 -
Cant logon to WindowsXP, deleted some registry keys
By chloec42 in forum ComputerReplies: 5Last Post: 14th Sep 2010, 00:26 -
Which keys are simulated?
By blagus in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jul 2009, 08:20 -
Lost CD Keys, need replacement software Freeware
By Mboyle in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2009, 15:32 -
Dual Boot OS use 1 or 2 keys?
By johnhammonds in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 05:20
