can someone recommend standalone hardware media player for use with TV? (device like WD TV Live media player)
Preferably the device which have built-in VLC media player as default player, that plays most multimedia formats.
For playing live video streams over the Internet.
Results 1 to 21 of 21
None, aside from a home theater PC. The small devices have very weak CPUs and use custom hardware accelerated video decoders. So they're limited to what those chips can do. Fortunately, the chips are pretty flexible and powerful these days and can handle up to Blu-ray spec pretty well.
Standalone media players don't include hardware or an OS that are sophisticated enough to run a software player like VLC. If you must run VLC, then you need an HTPC. If you must have a standalone hardware media player, then forget about finding one that runs VLC.
IPTV boxes usually require a paid subscription to a particular IPTV service provider to work. Permitting those who buy an IPTV STB to use their box for some other purpose is not in the interest of the service provider. The service provider makes a profit from selling their service. They make very little profit from selling the STB itself. If the IPTV box is for free services, then the box itself cannot be an expensive item or nobody will want it.
You need to define exactly what you want to do with a net top. If you want a media player that can run VLC and play media files, a net top could serve that purpose. However, if you want to transcode and stream video to the Internet, not all net tops will perform well at the task transcoding. If you want something that will allow you to watch streaming video from high-definition streaming media services, not all net tops can decrypt encrypted streams from some service providers or play the stream smoothly. -
Well, there are plenty OEM STBs models that are not tied to any specific IPTV provider.
I need specifically for watching streaming video from HD streaming media services, live TVs. (MPEG-1/2 Video(mpgv), H264 - MPEG-4 AVC(part 10) (h264), rtmp streams). VLC media player is very good for this. -
I don't know if you're into Android devices but this is a powerful device that'll do what you want.
http://www.timingpower.com/rk3066-android-mini-pc -
Translation:
This is a powerful Android device that MAY be able to do what you want, but nobody knows for sure because you can't buy one and they don't say how much it will cost if it ever goes back on sale. They're blaming "manufacturing delays" and promising to have them next week, but again, you can't buy one now nor will they tell you the cost.
So if you're very patient this MIGHT be an option - if it ever becomes available and it's not cost prohibitive. -
One of the Amazon reviews linked from that site says it costs $55. It gets somewhat mixed reviews but people (technologically proficient ones, anyway) generally seemed pleased with it.
There may be OEM STBs running Linux, but they do not have the same computing power as a PC. They do not need to have that kind of computing power because they are running proprietary, scaled-down versions of Linux. If they were to be enhanced to have the ability to run a more full-featured version of Linux and software players, like VLC, they would essentially be low-end computers and have similar price tags. If that is the that case, why bother making one? They would just end up competing for customers with existing low-power, low-cost computers.
Some net tops are powerful enough to allow watching streaming video from HD streaming media services, and some are not. Something based on older Intel Atom CPUs or AMD E-Series APUs may not have enough power for what you describe. The net tops that are powerful enough to handle commercial streaming services cost as much or more than a desktop capable of doing the same things. These are net tops using Intel Ivy Bridge and Sandy Bridge CPUs or AMD A-series APUs. I don't know anything about the performance of the new Atom CPUs that were just released in the past couple of weeks, so I can't say whether they are an option or not. -
*** Now that you have read me, do some other things. ***
I don't think that such small device will be able to play RTMP video streams without delay, picture cutting off/ freezing and pixelation. RTMP streams is particularly CPU-intensive, so it can play poorly if devices lack hardware acceleration for video. Android 2.x devices lack hardware acceleration for video. Consequently, the CPU has to do all the work.Last edited by siluet; 17th Mar 2013 at 06:10.
Apart from the WD and Asus box, most of those STB's make big promises, but rarely deliver. Check out the VIZIO Co-Star, it might do what you want, sort of. You can install the VLC client for Android, but you would have to set a PC with the VLC server to stream to it. You can also do the same with a PLEX server/client combo.
i can watch HD fom amazon, hulu , or Netflix
uing my sony media player
it also plays files from usb from stick or external HD
it does not play mkv, iso, or dvd folders,
it does play vob, mpeg, avi, dvix, xvid, etc.. -
What didn't see the Specs link at the top of the page. The PC is so you can stream any format that the box doesn't support in the first place. Anyway, never mind that, the Ouya console is actually happening and it supports XBMC. You just might have to wait to get one, I imagine supply will tight at first with kickstarters getting first dibs. If you can't wait, then get a Zotac ZBOX nano and run XBMCbuntu.
ISO: Standalone Media PLayer
By NotSoEasy in forum Portable VideoReplies: 7Last Post: 25th Feb 2011, 10:43 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Media Player for H.264 Hardware decoding
By W_Eagle in forum Software PlayingReplies: 2Last Post: 24th Jul 2008, 10:37 -
Media center video won't play on standalone dvd player
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2008, 22:04
